thermostat in the wrong place
huntingdeer
89 mercruser 305
Ok so i have figured out someone i think put the thermostat in the wrong place.I found it in the top housing? is it suppose to be against the block and the housing? why i ask is cause the motor always stays very cool.it never has got hot.
alldodge
Re: thermostat in the wrong place
89 mercruser 305
Never seen a thermostat directly against the block, they are usualy against the intake manifold. Do you have a oic?
huntingdeer
that is what i mint sorry.I can get one but it will be tonight.So it should not be in the top of the housing but the bottom aginst the intake.
alldodge
Between 1988 and 1995 there was three different designs. Only one design had the thermostat directly against the intake manifold. I need a picture of your housing or go to Mercury Mercruiser engines and parts and find your housing.
thumpar
Mine is in the housing with a spacer between the intake in the housing. If you look at the housing passages you can tell if it is right or not. The water should only flow into the the engine side once the thermostat opens otherwise almost all of it will go out the exhaust.
huntingdeer
i put the thermostat where i thought it needed to be in the pic.It was in the top.with it in the top it floats and nothing holds it down.
alldodge
You installed yours in the right place. You have the one Merc calls Design I. You need to have the sleeve 23-47508T and internal gasket 27-47510 installed to hold it down if it is not there. Here is the view
http://www.mercruiserparts.com/Show...r=210&bdesc=STANDARD+COOLING+SYSTEM(DESIGN+I)
huntingdeer
are you sure it shows it in the center piece not on the intake.smh can i buy one thing this is not rigged!! lol I do know all it had was just the seals no sleeve or ect.
huntingdeer
where you see the thermostat its on the intake in my pic but link shows different.
hall832
in the diagram you were given a link to it shows where it goes. it goes on top of the thermostat housing with a sleeve.
alldodge
one last dumb question with the seal and the sleeve on top of it in the top chanber how would the water escape? this is the sleeve i found. Mercury Quicksilver Thermostat Sleeve Part 23 47508T | eBay im confused or......? lol
It appears to be the right part, but after looking again at your pic in post 6 it appears the sleeve is there. The sleeve appears to be put in upside down from the top.
Once the block is filled up there is always a small hole somewhere , sometimes in the stat it self which allows small amounts of water to pass.
