thermostat problem????
stillhi33
1885 mercrusier 170hp/470 is the thermostat necessary for the engine to run?? or can you leave it out like the old american cars???
chiefalen
Re: thermostat problem????
speaking as a guy who used to drive them old american cars,motors are built to run a certain temp.not good to leave the t-stat out.
Limited-Time
Yes it will "run" but the cooling system will not function correctly. That may or may not cause other more expensive repairs down the road.
Ayuh,.... If you want it to run Properly......
Btw,.....
I don't think the 470s were Out back then......
