Water can pass through the block to quickly and not remove the heat effectively, as mentioned in your last thread, thermostats are removed due to inexperience to try and solve a cooling problem when in reality it masks a different problem. Fit a correct stat and see what happens, if it overheats, look elswhere for the cause.
