longstand
- May 2, 2009
- 293
i have remove the housing on my engine for the thermostat. so i could flush all the rust out of my engine. and then later after i have remove the majority of the rush i will put the thermostat back into my twin engine..
I know what and how the thermostat work. but this is a marine application..
i have also see the diagram of what and where the water goes when the thermostat is install properly. but for this marine application do i really need to install this thermostat.
also i have a water heater i believe there is two hose that connect to the housing for the thermostat to the water heater..?
how is the water heater work on the marine application. because i have trace a electrical wire that is connect to the side of the heater.. what is that two hose which lead to the thermostat housing..
