Re: thermostat
Top of each cylinder head there is a cover plate with four screws. <br /><br />Pick up two gaskets and two thermostats before you open them up and save some time.<br /> <br />When you take the cover off, note the direction that everything faces, so you can replace the parts the same way. Also, they are spring-loaded.
