Thermostat
SUP
Had two years of great running, now overheat. What sequence of problem solving would one use? Until my Seloc manual arrives, anyone know where the theromostat is located on a Volvo Penta AQ 131/275? Going the easy route first on running hot. Also, to check next, where is impellor on stern drive?
elpaso
Re: Thermostat
AQ 131 - 275<br />The sea water impeller is on front of engine,<br />not in the outdrive.<br />When looking from front - lower right side -<br />next to alternator. Will have 2 small brass<br />pipes - 1 in- 1 out. <br />The themostat housing is on heat exchanger,<br />and goes to the head.<br />As I remember ?
