Need help with my 50hp merc.serial number is 6308153 can not find thermostat on motor. Water comes out the pee hole then slown down to a drip. Asalo need diagram of the motor .thanks.....
It the water slow to exit the telltale, or does it reduce to a drip? If it reduces to a drip that is an issue. Are you running on the flusher or in the water?
