I bought a 1993 sportcraft with 217 hrs on the motor. The motor is a 570A. I had a water hose blow off a couple of times when I got up to 4000 rpm. When the boat is running this hose is so hard you can't squeeze it. I don't think this is normal.
I winterized the boat yesterday. In doing so I discovered it had a thermostat. Also, the stat was "cocked" in the opening. My guess is either somebody put it in wrong or something happened. I'm guessing this restricted the flow of water through the hose and this may be why the hose was so hard.
My questions:
1. Do I need the thermostat? I fish Lake Erie and cool water is always coming into the engine.
2. Is it normal for the water hose to get that hard or is something causing this to happen?
3. How normal running rpm can I run this engine? At 4000 rpm I still have more throtle. Besides having the hose blow off at 4000 rpm, I'm not sure if I should run any higher rpm.
My questions:
