tommays
- Jul 4, 2004
- 6,768
wild<br />the stat is normaly closed when cold and they are allways installed in a houseing that allows a low level of water flow to move through the block<br /><br />as the water flow warms up the stat starts to open to allow more flow based on the temp <br /><br />it can be anywere between its fully open and fully closed position and will move to a position based on the water temp that will try to allow only enough flow to bring the motor up to full temp<br /><br />the manifolds and risers allways get full water flow from the raw water pump the cir pump only moves water through the block passages<br /><br />if you fill the block from a high point the air is going to try to rise as the fluid takes its place and will gurgle out if <br /><br />tommays
