Thermostats
The --" mexican fellow "------Factory manual clearly says to put the round gaskets into the valve body first.----I believe there is a spot for them.-----So that would put them UNDER the flange of the thermostat as you say.
critter34
[QUOTE="racerone, post: 5618692, member: 431784"] The --" mexican fellow "------Factory manual clearly says to put the round gaskets into the valve body first.----I believe there is a spot for them.-----So that would put them UNDER the flange of the thermostat as you say. [/QUOTE] Ok thank you
