Nextelbuddy
- May 4, 2020
- 156
So I've made a few different posts about propellers and low wide open throttle at max RPMs on various places..
So so I went ahead and started digging in today
I went ahead and started to replace the cap rotor spark plugs and spark plug wires. I'm using Quicksilver Mercury parts for the cap rotor and wires. The plugs and replacing are the Quicksilver AC Delco MR43T
The The plugs that I'm pulling out are NGK 6 series plugs can't remember the exact number.
One of the spark plug wires I went to unclip and it wasn't even clipped in the boot was just resting on the spark plug itself but nowhere near attached so it looks like for starters my engine was running on seven cylinders and not eight. And then another spark plug fell apart on me when I pulled it out the porcelain just split so that looks like another plug that was not performing well.
In In that scenario my engine was pulling 4200 RPMs and getting a max speed of about 35 to 36 mph the quantity GPS and the onboard speedo.
I I wasn't able to finish the plug job tonight because the spark plug adapter I have is too long and thick to fit over the spark plugs with the current manifold configuration I found out the hard way. So it looks like I'm going to take my spark plug adapter home and cut it short and grind it down some to get it to fit better
Also I went to replace the coil and the coil that the previous owner had put in was some cheap Napa coil so I replaced it with a quick silver brand coil. I'm hoping that helps get a better spark for more power.
I'm curious if anybody else has any experience with an engine running on seven cylinders and yielding the RPM and wide open throttle I've been getting.
I'm really hoping that the soft issue in the engine runs a little bit better
Al also I tried clearing the flame arrestor clean with brake cleaner it was pretty clogged up with dirt and oil I still need to clean it some more because I can went dry and it was still pretty dirty.
I mean obviously the engine was down on power if it's only running on seven cylinders because I'm just looking for a little peace of mind before I try to get it in the water lol
