Thinning Gel Coat
Plainsman
Hello,
I received my Poly Gel Coat today with a Preval sprayer. Question is do I need to thin it and if so with what? I have read and seen, in pictures, good results thinning with acetone.
Any thoughts?
Eric
ondarvr
Re: Thinning Gel Coat
It's best to use products designed to reduce gel coat, but small amounts of acetone can be used to thin gel coat. Try to use less than 5%, much more can cause weathering and chalking problems.
ondarvr
Most places that supply gel coat have Patchaid type products, most have wax in them already, this will let the surface cure better.
