Re: This is for marine doctor
The problem is that I don't have an old case. I also have drilled the holes out on the midsection but now the alighnment pen doesn't line up. I figured if i got rid of the alighnment pin that I could retrofit the unit but there is some more differences. The water pump drive shaft and reverse gears are different part #'s But everything else seems to be the same according to epc. I just don't want to put this unit on and have major problems. Purchased unit as used and don't want to have to purchase a new unit.<br /> <br /> Thank you for your replies!<br /> JSaw
