This probably isn't good... Photos
diveman05
Bought this boat cheap and have had some issues with the engine. Its a 1968 Evinrude 55hp 3 cylinder engine. New spark plugs, new ignition, carbs cleaned, compression 115 in all 3 cylinders.
I finally got it started and it idles, doesn't run good when throttled up so i'm thinking just some tuning there but i put in a bottle of Seafoam (with 5 gallons of gas) to ensure everything was cleaned well. Mixed at 50:1.
Get it running on Muffs and after about 5 minutes i notice this gray sludge coming out of the prop... Its defiantly oily but i'm not sure where from. Any help?
busted-bayliner
Re: This probably isn't good... Photos
View attachment 155312View attachment 155313
smell it lower unit oil has a distink smell its prolly uspet fuel/oil if it smells gassy then it uspent fuel/oil an that normal
hidef
Out of the prop it is unburnt two stroke oil and gas. Do not rev the engine on the muffs it is not good for it.
boobie
After you get done running all the seafoam out of it let it idle for another 15 mins. Then take it to the lake and run the heck out of it.
orbanp
Do check the gear case oil. If that oil came from your gear case, you do not want to run the heck out of it!
Peter
kfa4303
Banned
A '68 should not be run on muffs. it must be run in a test tank with water filled to about and inch or two below the main exhaust port.
boobie
Why ? It's got the water pickups on the lower part of the g/c on the sides.
