Donald0039
- Jun 11, 2022
- 418
I have one of these drain plugs in each exhaust risers as it's closed cooling. Went to screw one back in getting ready for initial startup and it snapped. Looked at the other one and it snapped unscrewing it in the fall but I did not notice.
Do they not last very long? Cheap plastic? Blue is bad luck?
How to get the broken piece out? Not a lot of clearance going straight down. Only a few inches.
What is needed is a 1/4" by 3/4" long lag bolt that is LH threaded. The stuck piece has a hole in the middle I believe.
Good thing it's plastic so no corrosion holding it in.
Not sure this is an improvement over small brass drain plugs with NPT.
