Thoughts on trim pump and cover for volvo.
wellcraftpower
So i have finished my 5.7 motor build and will be dropping in this week . I can't stop thinking about the trim pump that has a leak . Its the one mounted behind the drive on outside of boat. It appears to be the updated cover. Can get a new cover for under 500 but with pump looking at 2500. which hurts. Looking for input on diagnosing the leak which looks to be coming from the bottom of the cover. The trim works and lifts the drive up and down. How do you know if the pump is bad and causing the leak. Thanks to anyone with experience with these pumps that can give suggestions.
Jeff J
All of them I have seen, but that is only 4 of them. Three Cobalts with V-8s and a Monterey with a V-6. All had the SX-A.
Jeff J
I have replaced a couple of the pumps but can’t remember if they can be removed from the bracket without disconnecting. Tipping it out of the bracket would help with cleaning and make the leak easier to spot. A light dusting of baby power is a great way to spot a leak but the pump would have to be clean and dry first.
It was suggested to me when I asked for advice on changing my first one to cut the wires and splice in the new pump. I found it easier to disassemble the plug. The clip that holds the harness seal in the transom is a serious PITA though.
volvo lost their mind by installing the pump outside the boat on the SX-A drive. turned a $100 oildyne 108 pump to a $2500 nightmare
wellcraftpower
yes i have seen that done and i could do that but you don't have to do that if your just replacing the cover.
