Threads with unread replies
NYBo
Anyone else having an issue with threads continuing to show that there are unread replies even though you've already read all of them? I have been having to use the "Mark This Forum Read" option under the Forum Tools menu. I am referring to the main page of forum sections where threads with unread replies are in boldface. This sounds like some sort of cookie issue, but I haven't changed any settings. I'm using Firefox 18.0.1 which came through around the time this issue cropped up, but I've had this issue periodically in the past with older versions of this browser.
NYBo
Re: Threads with unread replies
It's behaving this way with this thread!
The "View First Unread" button at the top of threads is also not clearing.
NYBo
Hmm. Behavior appears to be normal in IE 9.
NYBo
Clearing the forum cookies seems to have fixed the problem. :redface::sorry:
toneeees
Administrator
Not sure why that would have happened, but glad clearing cookies fixed it!
UncleWillie
The "View First Unread" button take me to the top of the last page of the thread but not down to the First Unread Posting.
It used to work consistently.
toneeees
Administrator
Hey Uncle Willie, it seems to be working fine for me. What browser are you using? You are talking about the "View First Unread" located at the top of this page correct?
UncleWillie
Using IE8
No, it is one menu level up the from the actual post.
Example.....
Forum > Other > iboats Forum And Website Issues/
To the left of the Post Titles, there is a small light blue circle with what look like two down arrows in it.
If you hover over it, it displays "Go to first new post"
It take me to the top of the proper page but not to the actual post.
aspeck
Doing what Uncle Willie is saying, it is working with Chrome ...
toneeees
Administrator
Using IE8
Example.....
We are looking into UncleWillie.
For some reason it doesn't work on IE 8. I don't even have IE, but tried it on a co-workers PC and it did not take you to the last post. So I'll see what's causing it to not work in IE :facepalm:, it would be awesome if browsers played nice together!
UncleWillie
Somewhat related, if this helps any....
After submitting a post it return to the top of the page and not the actual submitted post.
The 2am eMail links DO take you to the actual posts in the links.
The "View First Unread" button at the top of, and inside, of the thread, DO take you to the "First Unread".
toneeees
Administrator
We've figured the issue, just have not found a solution. It seems to work fine in the other browsers, just not IE. So that makes it trickier.
