I have three questions concerning my Yamaha 9.9 four-stroke outboard.<br /><br />First concerns possible overcharging from the alternator and what to do about it.<br />The alternator has a max output of 10 amps. Even feeding a bank of two wet-cells<br />in parallel, that's a lot of current to feed in over an extended time. The batteries get<br />up to 14 volts and possibly higher. Will this high charge rate hurt the batteries, although<br />they will build up resistance as they charge up? Would there be any damage to the alternator if it<br />were disconnected from the batteries at any time?<br /><br />Second question concerns the susceptibility of this engine to develop blocked jets<br />in the carburetor. Although I have and inline filter from my tank and another filter<br />in the engine fuel line, I had to clean the jets today after doing the same job a month<br />ago. Although I did not use the engine hardly at all in the interim, I was made sure<br />to run it for a few minutes every week, but it got progressively worse. My gas is typical gasohol, which I bought the beginning of the season. About mid season I added a carburetor cleaner and gas preservative to the main gas tank. Both my filters do not look very dirty. Pulling the carbs and cleaning the jets is a half day job,<br />so this is getting a bit tedious. Maybe they will someday design a carburetor with a built-in cleaning mechanism, like a needle plunger which can be operated without pulling the<br />carbs.<br />Seems like these types of carburetor problems are almost an epidemic, as engines are lined up at my mechanic for this same problem. Four strokes are<br />especially susceptible to this problem because of their fine diameter jets. Any ideas on how to minimize this problem?<br /><br />Last question is about throttle handle behavior. When increasing throttle with the handle control,<br />my engine does not react immediately and then it<br />reaches a point where it increases quite a bit with just a small turn of the handle. I can then<br />back off to try and find a good speed. Should there not be a smooth increase of engine rpm as the handle is turned?
