throttle Adj 1986 Mariner 60el
almell
Disregard this. Have solved problem Thanks. Al<br /><br />Have the Mariner 60elSVC manual. Adj: remote throttle placed at slow.Position throttle cable joint so aligns with set pin on magneto control lever.<br />Not sure of location of set pin. Picture in book is not clear.<br /> Next adjustment is the shift cable. Believe a problem exists there because when trottle put in reverse, reverse doesn't occur until throttle is pulled further back and gas is applied, grinding occurs and reverse is accomplished. <br /> u may contact me direct. ermell@att.net TU.
