Jconnell43
- Sep 4, 2005
- 85
1971 Johnson 50
Having trouble keeping it idling, runs rough, rebuilt carbs,good gas.
Can I loosen the clamp that joins the 2 carbs so that both throttle plates are closed, then tighten them in that position then and use the roller position to open them slightly against the cam, I have a feeling one is more open than the other.Is there a better way?
Also I have seen that timing is not an issue at idle, but how many threads should be showing ( roughly ) on the throttle rod with the clovis pin?
Thanks,
Jim
Thanks,
Jim
