JOHN HARTER
- Apr 18, 2004
- 11
I lost reverse and forward and traced my problem back to the shift lever assembly itself. Inside the shifter housing is a plasic (clutch?) with a notch, which I'm assuming is for neutral, where the switch toggle goes into. This is the same plastic peice that is attached the threaded knob on the outside that you pull for neutral. When shifting into forward it flips the switch up and, of course, down for reverse. My problem is that this plastic peice is not functioning properlerly which leaves me stuck in neutral or forward. Any ideas on repair or know where I can get a replacement?
