throttle cable problem 1972 johnson 50hp
bluebrownie
ok..so this newbie moved my 50hp from one boat to another...proud of myself...i am making progres... but i reattached everything, motor turns over...etc.... but the throttle is hard to advance or reverse....it was fine until this einstein moved the motor to another boat and had to disconnect it to do so...the manual doesn't tell me what to do... the throttle cable was brand new last year...shop put it in.... now it is all bound up....any help... also... how much of the extra cable should be sitting out in the back of the boat by the motor...? thanks for all your help...
freddyray21
Re: throttle cable problem 1972 johnson 50hp
it is possible you kinked the cable when putting it back in. All cable bends should be a large graceful bend to not kink it. If it is kinked you need a new one. post a pic of the cable. You can also unhook the cable from the motor and stretch it out straight to see if it moves easy. If if does then there is something binding in the motor. If not it's the cable. I am assuming you did not take it loose at the box.
bluebrownie
tx for the advice... i did not take it loose at the box... took it from the motor... although i know in the process of trying to figure out how to disconnect it... i know i rotated the barrel nuts (not sure what they are called...the brass fittings at the ends...) i will disconnect it at the motor and stretch it out... are they any specific adjustments to this or either it fits or doesn't sort of thing...? tx
freddyray21
the brass barrel are to adjust the cable. I have not looked at my manual to see, but I usually adjust them to neutral lines up with neutral on my control box, but I am running an old two stick box and an older motor. A kink in the cable is what I think it might be. Fred
