Throttle cable routing
harp2822
Anyone have a picture of how the cables run on a 53-54 25 horse evinrude?
Do you have all the parts?----The pulleys / cable / spring ?------Have not worked on one in a long time.----Magneto plate should rotate CCW when opening throttle.
harp2822
Ya got all the parts, it lets loose as you take the plate out. Took a ton of pics but not from the angle i need
harp2822
If you could move your camers out just a bit so i can see both pullys and the throttle gear, that would be a great help!!!
harp2822
Well another set back. I replaced points and condensors as well as coil packs.
Now there is no spark on either cylinder
