throttle cable slack
mellowyellow
'72 merc 1150, have about 3" play in the throttle cable. how do you take up the slack? manual is no help at all...<br />regards,<br />M.Y.
Re: throttle cable slack
on the ends of your cables, are there what look like scewable tabs? (similar to TV cable ends) if so you can tighten them there. If not the adjusters may be in the control box or engine attachments.
mellowyellow
thought they were screwable, but wasn't sure.<br />didn't want to torque it on a guess...<br />BTW, how's the weather in Victoria this time of <br />year? was married there (buschart gardens) 15yrs<br />ago....<br />don't worry, I don't blame you guys :(
Weathers hot and dry right now. Many love it, I don't, the trout fishing goes down hill till the fall unless you hit the mountain lakes. As for Butcharts Gardens I hope you liked it, my uncle pretty much runs the place. (well maybe not, but thats the way he tells it!!lol) I hope the cables are tight enough for you now. The way to tell is if there is any dead spots pushing up or down the throttle. They will be near idle or full throttle if they are there.
mellowyellow
still have a dead spot btw. troll and half<br />throttle. disconnected cable from motor but<br />doesn't appear to be any adjustment there.<br />control box???
Yepblaze
Maybe you're just trippin. <br /><br />It's gotta shift clearly into gear way before the trottle actuating. <br /><br />It's just the way most of them are.
mellowyellow
does that include a loss of cable tension?<br />engages gear ok, trolling OK, then at about<br />11 O'clock it has a dead spot with no cable <br />tension. shifter has 2-3" free play back and forth.<br />thanks,<br />M.Y.
