throttle cables and connection, 1996 force 70hp
atengnr
Hi, so I have this new to me motor, mounted on boat, and starting to look at cables and wiring. Force is new to me, so I could not visualize how the cables connect (dont have cables yet). Could someone look at this pic and explain? I see several threaded studs without obvious purpose. Thanks for the help.
jerryjerry05
The threaded studs are for an anchor point(2)
The other should be where the cable connects for the shift/ throttle.
Where's the nuts and washers?
Might be metric??
Top is for the shifter the bottom is the motor connections.
shopping
atengnr
Thanks. The nuts washes are missing. I may have one. Anything else that seems to be missing besides the cables?
atengnr
These cables were on the boat, I think used with an early 80s force/chrysler. This wouldnt work correct?
jerryjerry05
Those cables are the old Force/ Chrysler.
If the shifter is the F/C you'll need to change that too.
atengnr
THANKS. Got the cables. Is there a hardware store substutite for the little bushings that pilot on the anchor studs for the cables?
jerryjerry05
The cable should just slide over the studs and held in place with the 4 nuts and washers.
Closer pics of the area??
atengnr
Well I see it on parts drawings. From marineengine.com. The assembly drawing shows two bushings that slide on the stud. They are listed as $5.40 each so i hope i dont need them :) thanks alot
atengnr
Heres the drawing. Item 24 are the bushings.
dadofemily
There's a black plastic barrel with a threaded hole and is on the cable. It also has a non-threaded hole that slips over the studs. The hole is oversize, the bushings make up the difference. It might work without them, but would be real sloppy.
