Throttle Cam.-
Sea Rider
Was wondering why all OB engine throttle cams have progressive cam angle shape from idle to cam's beginning of high hill and then carb roller encountering an abrubt high hill cam when entering wot world. Why can't there be a progressive like shape cam from idle to wot for all engines ? If you have an easy to plane boat at just 3/4 throttle, don't need to count with a high hill cam, right ?
Happy Boating
steelespike
I would say the carb has to keep pace with the timing as it advances.
In the old days the carb had a separate control in the tiller with a separate lever
for the timing/stator advance. You could advance either separate from the other.
Would run strangely.
With the timing advanced you could control the carb slightly without touching the timing.
The timing/stator lever was marked stop,slow,start,fast
There were those with only the the timing/stator lever that picked up the carb as the timing was advanced.
Some stator levers had a kill switch included.
Frank Acampora
Typically on two cycle non fuel injected engines the carb cam will open the butterflies about 1/4 of their maximum at about 3/4 throttle on the control handle. At this point, timing is almost 100% advanced. What this does is to give better fuel economy at cruise. Note the difference is that at WOT on a recreational engine and boat the engine makes a lot more noise, uses a lot more fuel, but only drives the boat a couple of MPH faster. In fact, if you look closely, the linkage will slightly retard timing a degree or two at WOT. This is to help prevent piston damage.
Because of the nature of the carb, the high speed jet LIMITS the amount of fuel delivered at WOT. The reason is that as more air flows through a venturi it will get progressively richer until at WOT (if there were no high speed jet) it would be too rich for correct running. Thus, at about 1/4 opening the venturi is starting to deliver fuel and while it is less than at WOT, it is not very much less because it is close to the limit set by the high speed jet. So, you save a little fuel at cruise, but not as much as you would hope to save.
Most outboard carbs are dirt simple. They do have a low speed circuit BUT since the low speed circuit is always at manifold vacuum it aleays delivers fuel. The high speed jet is sized to account for this fuel. That is why if you set the low speed needle too lean the engine will melt pistons at or near WOT
