Throttle Only Feature Broken
ta400man
I am taking Don S advice and I need to repair the throttle only button (the button does not move at all). I believe this will allow me to crank over the motor and give the engine throttle at the same. I am new to boats, but not new to mechanics. <br /><br />I have a 87 Sunbird, 3.7L, merc470.<br /><br />Can I repair the control lever or is it recommnended to replace the assembly. I use the theory do it right the first time.<br /><br />How does the netrual lock out switch work? I would think that the switch cuts the motor if there is any throttle or does it cut the motor when the shift cable moves. I would assume the shift cable moving would the netrual lock out switch to cut the motor.
RubberFrog
Re: Throttle Only Feature Broken
Do you have a schematic of your control?
Bt Doctur
it prevents you from starting in gear.
ta400man
I do not have a schematic of my control. I wish I did.
tommays
The button disengages the shift cable in netural and allows the throttle to be pumped to prime the motor and placed in a good position to allow the motor to be warmed up<br /><br />There are service manuals for each type and brand of control DONT even think about trying to take it apart with out one :) <br /><br />tommays
ta400man
If I were to replace the control, what would everyone recommend?<br /><br />Is a brand name to use that I should use, or can I use cheap one and get the same effect.<br /><br />Thanks,<br />Shawn
boatforever
For some closure, I replaced that throttle control and the engine started up in two cranks.
Thanks
