I have been told that my motor (OG423431 1996 225 carb.)throttle pos. sensor settings should be 0.950 @ IDLE and 3.80 @ WOT.I checked this by turning on the key on the boat and checking the lav.wire with the red stripe with my digital volt meter at idle I had 3.70 Volts,and with the throttle wide open I had .77 Volts. this is backwards from what I was told it should be. I turned the sensor shaft 180 deg. and my alarm started beeping.Any one tell what's up with this,bad sensor,???
