When I start the engine, go forward, and then bring the shifter back to neutral, the engine stays in gear going at a very slow speed. I have to turn the engine off, bring the shifter to reverse and then back into neutral a couple times until the engine will start, telling me it's in neutral. The same thing happens when it's in gear, but in reverse. I have to shut the engine off and move the shifter around until it's finally in neutral (engine will start).
Anyone know what the the common causes for this are?
Thank you
Thank you
