Throttle
viper1
Been on goggle and here searching. But .. no luck. My 93 star craft has a quick silver throttle but don't know model. Every one says to pop the warm up button and remove nut. Well the only nut is the one who's trying to find it here. LOL! I have heard several people mention a set screw. Now there is a slot seemingly for it. But this old stiff guy cant see around it all. Any one know were it is and how i can get to it. I think the switch is bad on trim. Trim solenoids and all check good. But getting no voltage for the up from the throttle. But form where it plugs into trim pump assembly all is good.
Figured id throw that in as i see a lot of people suggest it. :) By the way my button is the round one about 3/4 in diameter and it come right off with two small screw drivers..
viper1
Re: Throttle
Hmm no Replies! Well I finally figured it out on my own and checked it out. By the way to remove mine was a simple set screw on the bottom of throttle lever. No need to remove button.
64osby
Re: Throttle
Viper, Glad you figured it out. Did you fix the voltage issue?
Most here tend to be visual types, we love pictures. They also help id the part you're working on.
