Bill kubiak
- Jan 31, 2004
- 629
Two three inch exhaust hoses lead up to a Y fitting that becomes a single 4 inch hose to a bronze thru the transom exhaust pipe. It has a 90 degree curve downward outside the boat. Inside that outboard part of the pipe is what appears to be an inverted bronze funnel with openings all around to let the exhaust out. On the opposite side of the boat is an angles forward brass thru hull pickup with a one inch hose that leads across to the inboard top on the the hull exhaust pipe. This pickuo just appears to pick up water and direct it to the exhaust pipe to mix with the exhaust from the engine.
What am I looking at? I think that funnel deal must act as sort of a valve or diverter to keep water out of the main exhaust pipe but what the heck is the small pipe for????
