Thru-hull exhaust
mike165
Would I get more HP or efficiency from this instead of the standard thru the drive,the motor is a 165 6cyl IL 250 Chev
in a 20' Tri it is WOT at 4000rpm with a 14.25x 17p 3 blade trimmed up runs at 62KPH on GPS.Motor is std 2b Roch runs on 98 oct and in good cond
QC
Re: Thru-hull exhaust
Conventional wisdom and data shows that only big blocks gain any real advantage. I would especially doubt any increase whatsoever from your setup.
Don S
Nope, you wouldn't notice anything but the extra noise.
mike165
Thanks QC & Don,I'll save the money
