thru hull fitting for raw water washdown
stevie007
What is the best sealant to use to install a bronze through hull fitting. I am installing a raw water washdown. No wood in my hull construction. I've been told to use life caulk and also others have said to use 3M 4200.
tashasdaddy
Re: thru hull fitting for raw water washdown
3m4200 on any thru hull application. anytime you drill a hole seal with 3m4200.
