Thru Hull Fittings
elahuta
Hi Guy, I have an older Formula that had a thru hull plastic transducer that cracked and was leaking water in the engine compartment. (Sinking the Boat!):eek:The transducer was not connected to anything so no loss but, here is my problem I need to fill that hole. I found a thru hull bronze fitting but, it has a hole in it to let liquid in and out. So, that will not work..
Does anyone make a thru hull plug?
If not , what are my options?
Thanks
Re: Thru Hull Fittings
Ayuh,... What you found would work with a valve on it....
Filling it,+ fairing out with fiberglass is always an option...
greg82255
I'd say its better to repair the hole with fiberglass...
