Re: Thru-hull questions - please help me keep my boat from sinking
Brian seacocks installed below the waterline come in a couple common varieties. Often you will have 3 set screws that go thru the exterior flange, thru the hull, and thru an interior wooden block* on the other side of the hull. The setscrews keep the seacock from spinning when you tighten the flange on the inside of the hull. Some seacocks (Groco) use a system of notches molded into the bronze and a special tool is inserted into the seacock from the outside. Someone holds the tool and seacock in place while someone else tightens the flange on the inside. Its a pain in the butt but your not dealing with the three setscrews.<br /><br />The flange you screw on the seacock from inside the boat, not the valve, completes the seacock installation.<br /><br />Any seacock that is installed below the waterline must have an accessible shut-off valve attached to it. In most cases it is a 1/4-turn ball valve. They are inexpensive and maintainable. That means you can take the ball valve apart and clean it, lube it, loose a part and put it back together wondering why it doesnt work anymore.
With the ball valve installed you wont need that cheesy plug anymore.<br /><br />Ball valves come in a variety of ports on the other side, away from the seacock. You can get threaded or hose nipple, whatever you need.<br /><br />You never want a below-the-waterline seacock with a hose barb/nipple on the inside. Why? Like I said, the first thing that immediately attaches to it is a valve. The valve will thread into the seacock.<br /><br />* The wood backing-block makes for a rigid and distributed mount so if you kick the seacock it wont break a chunk out of the hull and sink your boat. Also, seacocks are sometimes mounted where the hull curves so the wooden block can be shaped to the hull curve so when the seacock comes thru it has a perpendicular flat surface for the locking flange to tighten down against.<br /><br />Heres where I replaced an older style seacock with a newer style. This is how it is done BELOW the waterline. This first pic is from outside the boat. You can see where the three setscrews went in. As you look into the hull, the white material is the fiberglass. Right up against it, the light brown material furthest inside is the wood backing.<br /><br />
<br /><br />This shows the hole from the inside. On my boat the original wood backing block was shaped into a circle, like a donut. Looks pretty but isnt normally done this. Usually its just a square piece of wood glassed over and/or painted. That knarly looking green thing on the shelf above the hole is the old seacock. <br /><br />
<br /><br />Hes a close up of that pretty wood block. If you image yourself looking at the hole straight on you can kind of see where the setscrews came thru the block at about 10 oclock, 2 oclock, and 6 oclock positions. Sorry, if I make this pic any bigger it will pixelate
turn into square blobs.<br /><br />
