Thrust hub
Tbird64
So some how dispite having a tabbed over lock washer I lost a prop on the weekend off my 1970 ish mercruiser 120 sterndrive.
Worse than that I also lost the thrust hub along with it. (Part that goes on the prop shaft before the prop
Checked the local dealer and on line and sure enough not available. I have one of a newer version on the 120 bottom end but it does not match up.
Was hoping to get out at least once more before the season is over but it's looking like this might be the end of it
This is the part I need
https://www.perfprotech.com/thrust-h.../product/94887
Any chance somone might know where to get one or know of a substitute ?
Located in Ontario.
Thanks guys.
Fun Times
Hi there, since you know the part number (45451A1) you can search the number online under image search and also EBay within your area and should be able to find an old new stock or even used I'm sure. Here's some that I found under EBay in he US for example, https://www.ebay.com/sch/i.html?_fro...451A1&_sacat=0
Edit: ^ Chris beat me to the EBay idea.:encouragement:
