thrust washer
bigdaddy08302
Dumb question but does the thrust washer jsut sit on the shaft like a washer on a blot so it is easy to remove by hand or is it on the shaft tight? Removed my prop while waiting for new one and I dont see one there but the shaft does have what could look like a washer there but I cant just pull it off
craze1cars
Re: thrust washer
They often get stuck. Tap it with a hammer, it'll flop off.
bigdaddy08302
Re: thrust washer
Thank you...I feel like a dummy sometimes asking simple questions but It's better than using ahammer when one shouldn't....I appreciate the help
Texasmark
Re: thrust washer
Before you put it back on, grease the shaft and splines with a waterproof grease such as Lubriplate white. Also take note that (at least on mine) the thrust washer only goes on one way....the propshaft is tapered where it mounts and the tapers on it and the washer need to match.
Mark
