Re: thunderbolt 500 4 cyl. 70's switchbox grounded
If the engine is running then the trigger, stator, switchbox and coils are all ok. Putting the kiil wire to a 12 volt wire will not have done any damage, because with the engine running the kill wire has about 400 volts on it. 12 volts would look close enough to ground for the switch box to 'think' you wanted to stop the engine. When you get your meter check the output of the rectifier, If it's only at battery voltage, replace it.<br /><br />Chris.........
