Thunderbolt 800 Wiring Harness
hartleck
All the wiring in my old harness has cracked and brittle insulation so I went to order a new wiring harness from here on iboats and found this:
80 800 4 1970 3051041-3059820 414-2770
80 800 4 1971 3144219-3192962 414-2770
In an earlier thread I was told that my Serial#, 3052262, was a 1971. This shows it as a 1970. I really don't care which it is but I do want to get the right harness. Is the 1970 the one I should order?:confused:
carholme
Re: Thunderbolt 800 Wiring Harness
In the first place that is a CDI harness:
http://support.crowleymarine.com/attachments/token/96rqwddc9bgdqph/?name=414-2770.pdf
which fits both years, however Iboats own s/n listing refutes this and says that your is a 1971.
80 4 2986444 1971
80 4 3186263 1972
As the 1972 starting s/n is 3186263 which is higher than your 3052262, yours is a 1971.
The p/n for your original harness is 59741 for the 1971 800E and you will see from the CDI sheet that 414-2770, is a replacement harness for your engine.
Hope this makes sense.
Gerry
hartleck
As I look at the picture I can't tell if the wires are long enough to travel back to the control box. Is that harness a different part or part of this harness? Thanks by the way for the help. Sorry I'm having to bother you with this, but I really appreciate your help.
carholme
hartleck;
The harness which we have been discussing all along is the engine internal harness, ie; it goes from the various engine components to the male pug on the engine cowling, seen here as item 37:
http://www.crowleymarine.com/mercury-outboard/parts/445_70.cfm
Your external harness from the engine to the control box will be a different part number depending on what control box you have but I am assuming that it is a standard 7 wire harness.
Gerry
hartleck
hartleck;
...Your external harness from the engine to the control box will be a different part number depending on what control box you have but I am assuming that it is a standard 7 wire harness.
Gerry
Here is a picture of my control.
carholme
Here is a link to the control box parts. I have this box on my 68 Merc 500.
Do you want to replace the harness from the box back to the engine? If so is yours one piece from the box to the engine plug or is it split for passage through the splash pan?
Gerry
hartleck
Gerry
Yes, from the box back to the engine. It appears to be one piece going directly into the plug. There was no link.
carholme
hartleck;
I just wanted you to see the box assy and all it's parts. CDI has new harnesses as you saw re the internal harness. I would be careful about buying old ones off ebay as they are probably in the same condition as yours. Aside from brittleness of the wires, corrosion in the plug which attaches to the engine is often a problem as well as damaged or missing portions of the pin connectors.
CDI Harnesses:
http://www.cdielectronics.com/Products.aspx?Criteria=4
Gerry
hartleck
I just finished the external harness install today. The de-soldering was a bear but all came out well. The moment of truth when I turned the key after connecting the battery. Wow!!! the sweet sound of her turning over.:D My wife jumped out of her chair and hollered with joy. Now I'm working on the replacement of the control cables. The only problem is remembering where part 51 and 50 goes and how. If anyone has pictures I'd be very appreciative.
