1010kristi
- May 7, 2018
- 1
I was also getting no spark on my Thunderbolt IV V8. I have followed every suggestion in this post to troubleshoot the problem. I have replaced the coil (twice because I thought the first one might have been bad), the ignition sensor, the ignition module and all the spark plugs in the correct order. I’ve checked every wire and all the grounds for proper voltage but still no spark.
Finally, after 10 days of pulling my hair out, I followed the last suggestion in this thread to connect a random extra wire to the negative post on the coil. When I rapidly strike it to ground I FINALLY get a beautiful blue spark.
But now I don’t know what to do with that information. Obviously I can’t just have a random wire constantly sparking at the ground to cause a spark. My question: how do I find out why that is the only way to get a spark, remove that wire and fix the culprit?
PS I apologize if adding to this thread is not the appropriate way to add this question. I’ve never used a forum but this thread has been so incredibly helpful!!
