country cadillac 48
- May 14, 2013
- 35
I have a 1984 4.5 hp merc and the tiller throttle just barely turns at all when I try to turn it to any of the positions on the handle. I don't find any infor if there is a way to lube it. I've had the cover off and the flywheel. There's grease on the gear out of the tiller and the verticle gear that it meshes with. When I try to turn the electrical assembly by hand it turns but not easily
....very stiff. The throttle lever on the carb turns very easily when I disconnected from the bracket on the assembly. There is very few hours on this outboard but the tiller has always been hard to turn. I've work on a bunch of small engines and large but I just don't see how to make this turn the throttle easily. Sure would appreciate any help.
