Is it possible to convert my sea nymph bt175 17.6ft. tiller to a side console? both boat and motor(60 hp evenrude)are 1995 If so were would I get info.about doing it myself.
Hi david ja, you can do it. I don't have the info for you myself but, you're in the right place to inquire about it - the guys here are top shelf.<br /><br /><br />good luck with the project
Welcome david - Best bet is to find a boat like yours with the side console and see how the factory did it. You can also check with the factory direct. Have you spent any time on the INTERNET checking? Enter "sea nymph" on any search engine. I found one on the first page.
Won't be cheap.<br />You will need: console, steering system, controls and cables, ignition switch, wiring harness to motor, adapter for controls on motor.
