Tiller trim switch non-operational F50
twnichols
The trim/tilt switch will not work on my tiller handle 2005 F50. The remote switch on the cowl works. Any ideas what could be wrong?
Ray Neudecker
Re: Tiller trim switch non-operational F50
Most likely cause would be a wire disconnected. If it doesn't work either direction, the likely culprit would be red.
JUSTINTIME
corrosion
pull the switch and clean
