Tilt and trim......and pin?
larky
Greetings. I have recently acquired a 1984 70hp. This is my first outboard with power tilt and trim. I'm not sure how exactly to use the tilt,trim pin. which hole should I have the pin in? I'm guessing I should put it in a hole that would allow me to trim the motor too low. My thought is that I should be able to adjust it on both sides of the "sweet spot". Any advice is appreciated, thanks
Re: Tilt and trim......and pin?
Put the pin in the hole closest to the transom and leave it there.
larky
Ok, I might be over thinking this, but why the other holes then?
boobie
For different applications but when you have T/T put it in the lower hole.
larky
Thanks guys. It was a simple question, but I wanted to make sure I wouldnt damage the trim cylinder.
Is your unit power trim and tilt ?------A tilt only unit was available as well.----Is the hydraulic package mounted externally ?
larky
No, it's the whole power tilt and trim "factory" unit. Thanks for clarifying though. I am excited to Be able to tune this thing while on plane. And also while at the ramp it won't be like pulling a dead cow up out of the water, like my last outboard. :)
