Re: Tilt and trim bugged out
Ok little update. Today I went and found some fuses (a pain to find), and picked up a marine quality 3 way toggle switch seeing as to how finding the one on the handle may be problematic, and certainly expensive. First I replaced the fuse. Everything started working fine. Played with it a little and going down, again, it burnt out the fuse. Admittedly I put a 10amp rather than the 20amp that was in it since I was testing and didn't want to blow anything serious. However, it only blew it after adding fluid back to the reservoir and my lifting and lowering it 3 or 4 times at max extensions. Nothing hung up like it did at the lake. I replaced the burnt up 10 with a 20 and resumed making sure no air bubbles were in my lines. Everything seems to be working fine. Still leaves me curious as to what originally happened. Tomorrow if I have time, I'm going to run all of the wires and look for rubs/possible points where it could be submerged when the back gets some water. Thinking, I'm not quite sure I'd remembered to turn my bilge pump on and there was some water leaking in. That's another adventure to track down although the tube connecting the livewell to the pipe that comes out of the boat is def suspect. Still I'm thinking perhaps water got into a wire somewhere to cause the hangup.
On another related note, the piece that comes out to support the motor while you haul the boat (using it till I can afford a transom saver) doesn't want to stay tucked up against the transom when I go to lower the motor after moving it out of the way. It kinda flops back down just enough to hang up the motor just before it gets verticle. Anything I can do to tighten this up? I looked for screws/nuts and didn't see anything. It does appear to have a grease fitting. Perhaps adding grease would stiffen it up? I hadn't thought to add any since it's very very loose and I tend to think of grease as a lubricant only.
