GameOnSalmon
- May 16, 2012
- 46
Thanks For taking the time to read this... Bought this boat battery was out, 1976 starcraft with a mercrusier 165 GM 250 I6. Put battery in, Tilt Down Works, Checked Oil level and Filled.
This is a dual solenoid system... There is one Bullet wire - Purple with no where to plug in? Also the clear tube has no fluid and it appears the Tilt out, In is not working at all...
I have looked at the wiring diagram in the Service Manual, Not sure where to go now... as the outdrive is down and cannot be lifted... Any help will be appreciated... Here are the pics.. Thank You
