waunakoenig
- May 24, 2008
- 8
I have a 1969 Mercury 100hp with power tilt and trim. The motor is stuck in the down position. When I hit the buttons to raise it the motor makes the usual noise but nothing happens.
I'm not a mechanic and new to boat motor maintenance but I'm hoping someone can help me check for a simple solution before I take it in and pay for the fix. I've read a few threads on here that tell me adding fluid might solve the problem. I've attached a poor picture of the tnt motor-it reads use only ms grade 20 or 20w motor oil. Where do I add the oil and/or fluid?
I've also attached a photo of the left side of the motor. Right in the center of the photo there is what looks like a grease fitting. It has a flip top cover. What gets added here? Thanks for any help you can provide.
