TILT AND TRIM QUESTION
MATTKENSETH
WHEN YOU ARE GOING WOT DOES THE TRIM STOP GOING UP NORMALLY OR SHOULD IT GO ALL THE WAY UP AND OUT OF WATER IF YOU DONT WATCH IT?????<br /><br />1999 MERCURY 200 HP EFI<br /><br />MINE ONLY GOES SO FAR WILL RUNNING JUST WANT TO NO IF THIS IS NORMAL
roscoe
Re: TILT AND TRIM QUESTION
Depends on the motor. My old Force will continue up. But it is a single ram unit. <br />I believe yours has separate trim and tilt rams. And only the trim will operate while in forward.<br /><br />Go #17!!!
MATTKENSETH
OK HERE IS THE DEAL IF IM GOING SAY 25 MPH IT WILL TRIM UP AND OUT OF WATER BUT THE MOMENT I STEP ON THE HOT FOOT TO GIVE IT GAS THE MOTOR GOES WAY DOWN LIKE TO THE 2 RODS THAT STICK OUT.<br />IS THAT NORMAL?<br />SEEMS LIKE I GET MORE SPEED IF I GET ON PLANE GO 25 MPH TRIM IT WAY UP AND THEN GIVE IT AND LET THE MOTOR FALL DOWN THEN I GET SOME HALF DECIDE SPEED IF I JUST TRIM IT DOWN GET ON PLANE AND TRIM UP AS I GO TIL IT DONT GO ANY FARTHER I LOSE 9 MPH DOING IT THID WAY THE NORMAL WAY
rodbolt
its normal. its not supposed to run with it on the tilt ram. sonds like you need to adjust themotor height and add transom wedges.<br /> good luck and keep posting
