Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i bought a boat with a 90 hp mariner and trim works good was wondering if i need to put any oil in it, or grease in grease fitting on top of cyclender to tilt.
And did you realize the title of this forum is "Props" and has nothing to do with Tilt & Trim?. But since you asked -- if the fluid level is low you need to add some. If it's not you don't. If you see a grease fitting (anywhere) -- grease it. Some grease is better than no grease.
