tilt and trim switch inop....
Muddydec
My tilt and trim switch on the control handle on my 125 Force is inop. Need help to repair. Was working fine when I put it in the water then suddenly stopped working. The one up front where the trolling motor still works. Please help.
Thanks
Mike
WillyBWright
Re: tilt and trim switch inop....
Either the switch went bad or the power wire to it came loose. You can usually feel a bad switch, they either operate unevenly between Up and Down, or they get mushy. If it feels okay, concentrate on a wiring problem first (but don't eliminate a bad switch possibility entirely).
Muddydec
Thanks for your help, it was not the switch it was a broken wire at the bottom of the console. Looks like they tried to fix it before.
Thanks again.
Mike
